Closed Thread
Old 08-31-2024   #1
JT_n_CT_90_ZR1
JT_n_CT_90_ZR1's Avatar
Exclamation *BOUGHT* WTB: BCM for 1990 ZR-1
I am trying to get my ZR1 to crank over, I have literally changed every single thing including sensors and ECM. The only thing left is the BCM. My VATS us 15. Please tell me someone has some info on where to buy or any other options. This car only has 30k miles in it. I take manifold was pulled and vacuum lines checked. Installed new wires and coil packs. I?m getting desperate.
JT_n_CT_90_ZR1 is offline
Old 08-31-2024   #2
vdhdhb
Default Re: Wanted BCM 1990 Zr1
Pm me Whiteheadpaul34@gmail.co m
Sent from my iPhone using Tapatalk
vdhdhb is offline
Old 08-31-2024   #3
Maikeymouse
Does it crank ?
Check the relays under the dash.
Under the steering column.
It will let you think that you have a vats problem, but it?s a bad relay.
Maikeymouse is offline
Old 08-31-2024   #4
JT_n_CT_90_ZR1
It doesn?t even crank. Before I did anything the check engine light wasn?t coming on, then the digital dash started flashing ?system? (I think that?s what it was flashing) then the gauges went out, the car started running HORRIBLE, climate control started flashing every button I hit, and the information system went bonkers and illuminated everything BUT check engine.
ODDLY the radio and antenna still work.
Ohh and the parking and fog lights wouldn?t shut off but dimmed to like 15%.
Old 08-31-2024   #5
aafc
aafc's Avatar
I do not have any thing to help, except you should get the FSM for your car
ZR-1. Also check solutions in the zr-1 net registry forums.
aafc is offline
Old 10-03-2024   #6
JT_n_CT_90_ZR1
FSM? Is this like a piggy back or a whole new system? I?m assuming this is replacing the BCM?
Old 08-31-2024   #7
phrogs
phrogs's Avatar
Well I have a 1990 bcm think the vats is #10. Car had under 45k miles
JOHNNY P
Currently own
phrogs is offline
Old 08-31-2024   #8
tpr60
Have the battery checked/load tested, check the fuseable link wires next to the battery.
tpr60 is offline
Old 09-01-2024   #9
JG95ZR1
JG95ZR1's Avatar
Check the purple wire to the starter and see if it gets power when you turn over the key
JG95ZR1 is offline
Old 09-01-2024   #10
Maikeymouse
Like tpr60 said, check battery and terminals.
Have the battery load tested.
Check you?re ground wire to chassis and engine.
Closed Thread
