Old 06-25-2024   #21
Tim555
Default Re: Engine noise- stuck lifter?
Cut the filter open today. This is what I found. Some small silver particles. No gold ones like were in the oil drain pan.
https://youtube.com/shorts/kakxFT_zq...QastpxuNvXhddD
Tim555 is offline   Reply With Quote
Old 07-25-2024   #22
Tim555
Results are back from the blackstone oil analysis. They didn?t seem too concerned. It doesn?t seem like the bearings are wearing, but there is a lot of iron and aluminum. Could one of the lifters collapsing, which may have caused the an engine noise, resulted in a cam lobe or lifter itself getting beat up?
? Using a fuel additive before sampling can result in a low flashpoint, but not in this case. No
water showed up either. Aluminum (pistons), iron and nickel (steel parts) are high compared to averages,
which are based on a 2,400-mile run. Copper looks fine on a microscopic level, but if you find more visible
metal next time then there might be an issue with brass/bronze parts - let us know if you find more metal
next time. The slightly low viscosity isn't a concern. Check back in 1,000 miles to see how metals are
trending?
Old 07-26-2024   #23
Originally Posted by Tim555 View Post
......... Some small silver particles.........
See if they stick to a magnet.
Old 07-26-2024   #24
Tim555
They do
Old 08-03-2024   #25
Tim555
When changing the oil I noticed this part appears to be loose. It looks like the timing chain tensioner. See the video linked below. It also looks like the chain is rubbing on something. There are rub marks visible. Is this normal?
https://youtube.com/shorts/lVDWThbNe...VWj6Dx96yDdgfn
Old 08-03-2024   #26
The video looks like the facing for the top chain guide (attached to the cam cover) has come loose, broken or detached. It is not a common thing but has happened before.
The Cam Cover has to come off & the wear strip attached. It snaps onto the guide. The Guide is simple, just a flat plate, about 1/8" thick, with notches on each end.
Old 4 Weeks Ago   #27
Tim555
Thanks for providing that insight. Do you have those wear strips in stock? What are they made of? Does the chain always rub that much on them? In wondering if they?re the culprit for my shiny oil and high iron content that blakcstone said was in my oil.
Old 4 Weeks Ago   #28
You are welcome.
Yes : https://www.jerrysgaskets.com/facing...new-90-95-1f4/
Plastic:
Not much if the chain tensioner is working properly.
I don't think so, as long as the guide facing is still in place. From the photo, looks like to be detached only on the end you are looking at and maybe laying down lightly on the chain. It is hard to tell from the picture. You can probably tell better looking at it with a good pen light.
Old 4 Weeks Ago   #29
Tim555
You are welcome.
Plastic:
Is the only way to get that end reattached to pull the cam cover?
Old 4 Weeks Ago   #30
Tim555
I was able to remove the passenger cover so far. The chain guide was still firmly in place. There was writing on the inside of the cam cover as shown in the photo. Is this factory, or has someone been in here before?
