Old 04-18-2024   #1
scorp508
Question Is there a $F0 source/assembly file anywhere?
Many years ago I went through the attached file to create a larger $32B XDF for myself to use in TunerPro with my 1987 Coupe. It took a while but was a fun learning experience while getting it correct.
Has anyone come across a similar file for $F0? I'd like to learn more on how some of the variables interact and see if there's anything worth adding not already in the definition.
scorp508 is offline   Reply With Quote
Old 04-20-2024   #2
tiegsd
tiegsd's Avatar
Default Re: Is there a $F0 source/assembly file anywhere?
Can't vouch for whether these are any good, but found a pile of them here, looks like it may be what you're after?:
https://www.tunerpro.net/downloadBinDefs.htm
At very least, maybe a good start.
1990 Black/Black ZR-1 #1155
Old 04-22-2024   #3
scorp508
Thank you but not quite. The XDF files are what tell a program like TunerPro how to interpret a BIN's values, so you can edit them. The ADS files are for interpreting the ALDL stream of data while logging.
The stuff I'm looking for would be the original assembly program GM used for the ECM itself, sort of like the file I attached for 32B in the first post. Those can be read to determine the address locations of other switches, scalers, and tables that may not already in in the XDF or just to better understand how they interact with each other.
It's a little nerdy to want to read them, but it's the kind of thing I enjoy combing through and building a few more wrinkles in my brain.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 04-22-2024   #4
Contact XfireZ51
He may know if there is one or not
Old 04-28-2024   #5
tiegsd
tiegsd's Avatar
Rgr, thanks. Not familiar with TunerPro, so wasn't really sure what I was looking at. I dig that kind of stuff myself though, wanted to dig into it a bit. Not familiar with how GM did its software engineering back in the day, but I imagine they did not provide assembly source for their ECMs to just anyone who asked for it. Interesting reverse engineering problem.
Old 04-29-2024   #6
There are some who got the code ?over the transim? and some who can disassemble the Motorola assembler code.
Old 04-30-2024   #7
scorp508
Cool Re: Is there a $F0 source/assembly file anywhere?
I would love to speak to those who can of you have a suggestion.
Old 05-01-2024   #8
I would go to thirdgen.org. There are members there who have been responsible for many of the tools we have today for tuning, particularly OBD1.
Old 05-01-2024   #9
scorp508
Good idea. I cast the line and will see if anything bites.
https://www.thirdgen.org/forums/diy-...able-read.html
Old 05-04-2024   #10
tiegsd
tiegsd's Avatar
Rgr. I was poking around last week for a motorola chip diassembler, looks there are a few running around of unknown (to me anyway) quality, and IDA may be able to do it in the paid version, still looking into that.
