Old 04-17-2024   #1
Raykahn
Raykahn's Avatar
Default starter rebuild kit
Is there a kit available that would let me rebuild a starter myself? Or a list of parts needed?
New starter is already in the car. I can send in the old one for a core refund, or try to learn from it. I'd rather try to learn if possible.
Raykahn is offline   Reply With Quote
Old 04-17-2024   #2
dredgeguy
dredgeguy's Avatar
Default Re: starter rebuild kit
Right in Wazoo's hands. Come on Saturday for maintenance day and Dan can show you what he did with mine. I believe we have several rebuild kits at Jim's.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 04-17-2024   #3
JG95ZR1
JG95ZR1's Avatar
The solenoid plunger I have never located new the contacts are available
JG95ZR1 is offline   Reply With Quote
Old 04-24-2024   #4
Matt B
Matt B's Avatar
Charlie, can any of you wazoo guys bring a set to the MR / gathering?
I urgently need one and that's my ultimate chance to get it...
Thanks!
ZR-1 #638/1991
Old 04-24-2024   #5
dredgeguy
dredgeguy's Avatar
Hi Matt, unfortunately I will not be able to attend this year but will check for you.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 04-25-2024   #6
dredgeguy
dredgeguy's Avatar
Matt, sent you a PM.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 06-10-2024   #7
anton28
Hey guys. I need to rebuild my solenoid as well.
From my research, I see that I need the Denso 053660-7061 plunger kit, which comes with contacts and a plunger.
Will I need anything else? Is there a how-to write-up I can reference?
anton28 is offline   Reply With Quote
Old 07-06-2024   #8
anton28
Well, I was able to purchase the Denso 053660-7061 plunger kit and just went to purchase another one for a second starter, but I'm told it has been discontinued, and I can't find it anywhere online.
Does anyone have a lead on one?
Old 10-03-2024   #9
KJL
Did you ever find one?
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
Old 10-07-2024   #10
Young1
Young1's Avatar
File the contacts to remove carbon deposits. I even use a die grinder stone on my battery drill to shine them up. The starters seem to require it at 30-40k miles of use.
Steve Young
Second Owner
SOLD
SOLD
