#21 |
![]() ![]() Join Date: Nov 2007
The 93-95 Z's do not benefit from the relay mod. Only the 90-92 MYs do.
#22 | |
![]() Join Date: Jun 2006
H ![]()
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
#23 |
![]() Join Date: Feb 2011
Not trying to dig up a dead horse and beating it, BUT has DNS ever happened during cold weather?
#24 | |
I understand the Winter issues for batteries, and experienced the dreaded clicking or dimming of headlights, but never the Does Not Start after driving. There is a workaround for DNS as part of this thread. My thoughts are that DNS condition doesn?t happen in the Winter and only in the Summer. I was wondering if anyone on the Forum had the DNS in the Winter. In general, batteries last longer in the Northern climates versus the Southern climates. Sent from my iPhone using ZR-1 Net Registry
#25 | |
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
#26 |
![]() Join Date: Feb 2024
#27 |
![]() Join Date: May 2022
If it were me I would first try to get someone to jump start it..
second I would let cool and also disconnect neg battery cable for a while till cool. reconnect and try starting, Third or second I would push start .. push roll the car and pop the clutch to start,with the ignition on ... and not turn the car off till at your destination other than that it could just be a bad starter or ..other issue.. |
#28 |
#29 |
I have not but just posted and update to the thread I had started on this issue:
https://www.zr1.net/forum/showpost.p...1&postcount=24 |
#30 |
Update on my problem. A new starter put in by the dealer who sold me the car DID NOT fix the issue. Despite the clutch switch working, and not showing a resistance issue on the voltmeter, I decided to jumper it out anyway with some 12ga wire. Well I?ll be damned if that didn?t fix it. I ops tested it by getting the car hot and having the no start issue, and then putting in the jumper and it starts. Lesson is even if your clutch switch is good, it might still be bad. I will probably install a starter relay as a permanent fix. I did have the drive belt jump off or break while I was doing this, but luckily I was a mile from home. I?ll work on that this week?
