Old 01-16-2024   #1
onetinsoldier
Default Horsepower difference ?
Heres a dumb question...........the first ZR1's had 375 hp , then it jumped to 400 hp, what change or addition made the difference in horsepower gain ?
onetinsoldier is offline   Reply With Quote
Old 01-16-2024   #2
Default Re: Horsepower difference ?
Originally Posted by onetinsoldier View Post
Here's a dumb question...........the first ZR1's had 375 hp , then it jumped to 400 hp, what change or addition made the difference in horsepower gain ?
The '93 to '95s were rated at 405 HP. I believe the gains were due to some better porting and exhaust also with some chip tweaking but Marc and others could say more definitively. --Bob
Old 01-16-2024   #3
onetinsoldier
I believe you are correct, porting and some change in cam grinding , gave it the 30hp gain . I know chevrolet used to retard cam timing years ago for emissions and hp reduction to meet standards.
Old 01-17-2024   #4
rkreigh
improved intake port alignment. Bit better heads and cams, improved exhaust and header/cats.
405 hp blocks also had 4 bolt mains and all of them were made in 1993
Old 01-20-2024   #5
Hib Halverson
>Mild port/polish on intake and exhaust ports.
>better blending of the ports just above the valve seats
>Three-angle valve seats
>"Sleeve spacer" between the head and injector housings to improve alignment
>Revised cam timing but cam profiles remained the same
>Revised calibration
>New exhaust manifolds...which actually cost 5-hp but went to production to solve a problem with the engine ingesting debris if the cat converter substrate failed at high rpm.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-21-2024   #6
>Revised calibration
Always glad to have your wisdom around, Hib. I had forgotten all the details and especially about the cat debris ingesting problem. --Bob
Old 01-23-2024   #7
Matt B
Matt B's Avatar
>Revised calibration
That last point sounds really bad!!
ZR-1 #638/1991
Old 01-23-2024   #8
That's because...... IF & When it does......... it Really is!
Referred to as catalyst reversion. Occurs during engine de-celleration, i.e. lifting throttle with clutch engaged at high rpm.
All that's left of the Oil Control Ring lands, is that short section on the left end.
Old 01-27-2024   #9
Hib Halverson
Some of that info came from GM press info that was distributed in the 1993 long lead book.
The rest of it came from a conversation I had many years ago with Graham B.
Hib Halverson
Technical Writer
Old 01-28-2024   #10
tiegsd
tiegsd's Avatar
Oh wow. Have to assume that happened to a few cars until someone figured out what was going on?!
1990 Black/Black ZR-1 #1155
