Old 11-02-2023   #1
AlbanyBrian
AlbanyBrian's Avatar
Default Winter projects
1993 #135 in now off the road for the winter. The project list is:
+) F/R wheel bearing/hubs (completed, AC Delco golds used as replacements)
+) Pinion seal replacement
+) Steering column pivot pin replacement
So one project checked off the list and a couple more to go. Before removing the old bearing/hubs I measured deflection at the wheel rim lip. All 4 had noticeable deflections when off the ground and moved by hand. Ranged from 0.025? to 0.040?. One rear came apart when removed from the knuckle. Not sure all 4 are the originals, but now all are fresh.
Brian
AlbanyBrian is offline   Reply With Quote
