View Poll Results: How many miles are on your Z?
0-20k 27 18.37%
20-40k 44 29.93%
40-60k 28 19.05%
60-80k 17 11.56%
80-100k 12 8.16%
100k+ 23 15.65%
Multiple Choice Poll. Voters: 147. You may not vote on this poll
Old 09-16-2023   #1
Default Re: Mileage
1995 # 186......LT-5.....95,500 miles
1991 # 1427....LT-5.....53,800 miles
1990 # 72.......LT-5.....46,000 miles
1990 # 3032....LT-5.....62,200 miles...Last 1990 sold
1990 # 2067....LT-5.....81,200 miles
1990 # 8550....L-98.....74,300 miles
All ZR-1s have..........
All ZR-1s have??..
C4 Beam Plates, Billet Aluminum Pulleys (Alternator, Water Pump, Power Steering), Carter Bling, Oil Cooler SS Braided Hoses, TB Coolant Blocked, New 180 deg Thermostat, New Radiator Hoses, Debris Screen, Haibeck Chips (91/87 Octane), New Aluminum Radiator, New Charcoal Canister, Reconditioned Starter, 60/80 Amp Starter Relay, Battery Disconnect, Full Power Key Reconditioned, INFL REST Sensor Re-installed, New Linkage for Secondary Port Throttles, Billet Aluminum Fuel Pump Connector, New Secondary Vacuum System, New BKRSEIX Spark Plugs,, New Serpentine Belt, New Hood Strut, New Hatch Struts, Wilwood C5-Z06 Front Brakes, Clutch Safety Switch Bypassed, Anodized Steel Belt Tensioner Pulleys installed, 10W40 Amsoil Engine Oil, 10W60 Castrol Transmission Oil, 75W90 Mobile 1 Differential Oil, Differential Drain Plug Installed.
All additional modifications described in Signature below 👍
