08-21-2023 | #1 |
cruise control drops out
My cruise control will set, drop out when braking and resume normally, then just drop out randomly.
Then, sometimes it will Resume on demand, sometimes not. Sometimes it can be re-set, sometimes not. Turn it off/on then sometimes it sets, sometimes not. Wait awhile, turn it on, set it and it will work for a while, then randomly drop out. Any suggestions? |
08-21-2023 | #2 | |
Re: cruise control drops out
08-23-2023 | #3 |
Yes FSM. Check 30 year old vacuum hoses for cracks at bend going into module above battery. Probably minutely cracked. Trim off an inch or so and reinsert.
08-24-2023 | #4 |
What is a FSM?
08-24-2023 | #5 |
Factory Shop Manual or more correctly Factory Service Manual. They have diagnostic schemes for finding a vacuum leaks or other malfunctions. --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 08-25-2023 at 10:42 AM. |
08-24-2023 | #6 |
Also check for cracks on the vacuum line supply in the middle of the passenger side of the plenum
08-28-2023 | #7 |
Check the vacuum switch down on the brake pedal...often cause leaks in the system.
Best thing in life is a ZR-1 ride |
