Old 08-02-2023   #1
Matt B
Matt B's Avatar
Default Cruise control issues
My cruise control suddenly stopped working. Parked the car after a ride where I successfully used it but can't activate it now.
I visually checked all wires and hoses but found no obvious issues. Fuse is okay.
Any suggestions?
ZR-1 #638/1991
Old 08-02-2023   #2
Thomas ZR-1
Thomas ZR-1's Avatar
Default Re: Cruise control issues
Maybe a leaky brake or clutch pedal switch
[SIGPIC][/SIGPIC]Best thing in life is a ZR-1 ride
Thomas ZR-1 is offline   Reply With Quote
Old 08-04-2023   #3
Any suggestions?
Check the hoses at the CCM on top the battery. Then check the hose nipple on the center of the drivers side of the plenum. These tend to dry rot.
After that check the orientation of the brake switch on top of the brake arm above the brake pedal. If the switch is not centered on the brake pedal arm. Center it and try the cruise again. If the switch is offset the cruise will not set.
Old 08-06-2023   #4
Matt B
Matt B's Avatar
Thanks gentlemen! I found a loose vacuum hose. As soon as rain stops for a considerable time I'll test the result!
ZR-1 #638/1991
Old 08-11-2023   #5
Young1
Young1's Avatar
Ditto Mr Gold C.
Steve Young
Second Owner
SOLD
SOLD
Old 08-13-2023   #6
Hopefully it's that's simple.
