06-22-2023 | #31 |
Re: After Market Air Filter Housing Question
Morning,
Take a small piece masking tape, double over itself and place on the radiator shroud ,then place your cut REFLECTIX into position, then install your air box. If you cut the REFLECTIX a little smaller then the bottom of air box no one will see it when you are done. I cannot remember if I had to cut out for the holes to mount the air box to the radiator shroud. It's not a big deal to do this. JOHN |
06-22-2023 | #32 | |
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
06-24-2023 | #33 |
John,
Appreciate the clarification that Reflectix is not adhered to the back of the air filter house and is just held in place by pressure. Thanks, Gary .... |
06-24-2023 | #34 |
06-26-2023 | #35 |
John,
Sorry, am a bit confused on what you're recommending covering with Reflectix. Photo of backside of air filter housing showing area over radiator. Appreciate your clarification on how much of the backside you actually covered with Reflectix. Such as from the outlet mouth to the vent holes or ? Thanks, Gary .... |
06-26-2023 | #36 |
I FOUND APICTURE OF THE RADIATOR SHROUD WITH THE RELFECTIX IN
POSITION. JOHN https://www.zr1.net/forum/picture.php?albumid=452&pictureid=3967 |
06-26-2023 | #37 |
John,
Thanks for the photo. Please correct my observations, if I'm not interpreting photo correctly. - Narrow end is the output of the air filter that connects to engine air input - Fat end does not hang over the radiator coils Thanks, Gary .... - |
06-26-2023 | #38 |
OK,
Just cut the RELFECTIX TO FIT ON THE BACK SIDE OF THE AIR BOX THAT GOES TOWARDS THE RADIATOR SHROUD. YOU CAN CUT IT A LITTLE SMALLER THEN THE BOTTOM OF THE AIR BOX SO NO ONE CAN SEE IT STICKING OUT. HOPE THIS HELPS JOHN |
06-29-2023 | #39 |
John,
Thanks for your input. Attached photo of Reflectix added to backside of air filter housing. Reflectix tacked with spots of RTV. Thought about covering the other area shown, but was afraid the Reflectix might tear and block air conditioner condenser. Appreciate everyone's input. Gary .... |
