#31 | |
I'm ordering the parts to rebuild my tensioner and these infos/pics might come handy. Last edited by ZBrink; 01-24-2025 at 01:06 AM. Reason: Duplicate messaging already earlier in thread |
#32 |
![]() Join Date: Jul 2017
Great post, going to have to do this soon, super helpful!
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) ![]() |
#33 |
![]() Join Date: Nov 2016
Looks like Dave hasn't been on in a few months. I hope all is ok with him. Anyone know him in the outside world?
#34 |
![]() ![]() Join Date: Dec 2003
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
#35 |
I attempted this tensioner rebuild and cracked my back casing on the factory LT5 Tensioner while trying to tap the fresh tension spring in. I've called all around and nobody has a used/core available for sale.
I just installed a slew of new parts including injectors, radiator, ignition coils, starter, cam sensor, and knock sensor to get my ZR-1 Back up and running and now I'm dead in the water since I can't get a replacement tensioner. Can anyone give me some guidance on how to compress the spring to fit in into the housing? I'm trying to practice installing the spring back in the L98 Donor Part casing, and I've used a vice, and a set of 20" Pliers to try and compress it and no matter what I do I can't get it compressed enough to fit back into the casing... |
#36 | |
ManPro - I ended up putting the spring in a vice with half of the width of the spring exposed. This allowed me to compress it enough to get the cover started. Once you get it started you can remove it from the vice and use a pair of channel grips to fully seat the spring. |
#37 |
Forum Chairman
![]() ![]() Join Date: Feb 2024
Does anyone have the current part # for the L98 tensioner? Everyone seems to be out of stock of the Dayco 89298 which makes me think it may have been discontinued. Or, does anyone know of another tensioner that has the same "guts"?
Zack Brinkmeier - Forum Chairman, ZR-1 Registry forum@zr1netregistry.com 1990 ZR-1 #299, Bright Red/Red Last edited by ZBrink; 04-07-2024 at 01:26 PM. |
#38 | |
![]() Join Date: Aug 2006
https://www.ecklers.com/1988-1991-co...B&gclsrc=aw.ds |
#39 |
![]() Join Date: Aug 2010
Ecklers claim this to be correct for LT5. Can anyone confirm this??
(Ecklers current in-stock tensioner does NOT fit the LT5, you can however use the guts to rebuild yours - ZBrink) Last edited by ZBrink; 01-24-2025 at 01:10 AM. Reason: add details and context |
#40 | |
