Old 03-23-2023   #1
Norwegianmopar
Norwegianmopar's Avatar
Default Royal Purple oil filters
Has anyone tried Royal Purple oil filters on their car? I use their oil since my mechanic sells it and he asked me if I knew of anyone who had tried the RP filters on a LT5.
Access to Bosch 3401 or AC Delco PF970C (blue) here in Norway is very limited at best.
All input on other good filters are appreciated too.
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 03-24-2023   #2
longhorns05
longhorns05's Avatar
Default Re: Royal Purple oil filters
I've been using Wix on mine. Mobil 1 is another choice as well
longhorns05 is offline   Reply With Quote
Old 03-25-2023   #3
How would one distinguish good vs. bad oil filter trough use? I think the only way is to disassemble and compare the quality of internal construction.
Old 03-25-2023   #4
Norwegianmopar
On our cars it's a lot about anti-drainback, how well the filter keeps the oil when the car is parked.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 03-25-2023   #5
Marc Haibeck has some good information on his website about oil filters: http://www.zr1specialist.com/HAT%20W...ers%202006.htm. --Bob
Old 03-25-2023   #6
Thank you for reminding me of anti-drain back being critical. Perhaps checking the weight before install and after engine shut down after so many hours would provide a meaningful info.
I seriously considered pre-luber a few years back. But then, blown head gasket, rebuilding the motor twice, sent me in a different direction. Now a days, I log less than 5,000 miles per year and the Z will probably out live my left leg.
Old 03-25-2023   #7
I use Mobile M1-207s.......
I prefer an oil filter that will not create a mess when removing it over night since the LT5 Oil Filter sits on top with opened end down. A Mobile M1-207 works perfect in that case.
Post 3 - LT5/ZR-1 Fluids
Old 03-26-2023   #8
Norwegianmopar
Marc Haibeck does not recommend the Mobile M1 due to poor anti drainback (ref article on website). Could the lack of mess be due to the filter being almost drained out?
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 03-26-2023   #9
Young1
Young1's Avatar
Go ahead and try the Royal Purple if your mechanic and dealer can get it for you. Support the locals. The engine will tell you on start up if it likes it or not. Fram, Bosch, Delco were no go clattering for me. Sticking with WIX 51324.
Steve Young
Second Owner
SOLD
SOLD
Old 03-26-2023   #10
Norwegianmopar
I ended up buying the Wix 51324 too, only the Euro version ia all black with a different number.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
