Old 01-19-2008   #1
rogerzr1
rogerzr1's Avatar
Default Clutch cap stuck
I was going to add some fluid to the clutch, got the ECM out of the way, but can't budge the cap. I am scared to force it too bad as it looks like I could break the whole thing. Any tips?
Never mind. I went ahead and forced it. It came off ok. Sorry.
rogerzr1 is offline   Reply With Quote
Old 01-20-2008   #2
lbszr
lbszr's Avatar
Default Re: Clutch cap stuck
Sounds like you did the right thing, "If it jams, force it. If it breaks, it needed replacing anyway"; Flugg's Rule ...
Old 01-20-2008   #3
RedSled
I was about to do the same thing today. I haven't looked it up, but does it take much to get the ECM out of the way?
RedSled is offline   Reply With Quote
Old 01-20-2008   #4
bradslt5
no its easy . just take off the 2 10mm bolts spread the plastic holder a little with your fingers. and its loose. hope this helps
Old 01-20-2008   #5
RedSled
Will give it a go. It's just nice to have advice even on the easy stuff when you haven't done it before to keep from going "oh sh*t" after you crack something off. The manual is always so helpful - it goes into the great detail of saying something like "remove ECM." Thanks!
Old 03-02-2008   #6
RedSled
OK. ECM out of the way and yeah...that darn cap is stuck. Does it twist off or just pull up. It is stuck on there hard. Thanks!
Old 03-02-2008   #7
Jeffvette
Sometimes they take a little bit of force. They are pretty tough.
Old 03-02-2008   #8
QB93Z
QB93Z's Avatar
You have to unscrew the cap. Some times it takes a little extra leverage since it is hard to get a good grip on the cap.
Old 03-04-2008   #9
Jason 91
Jason 91's Avatar
I found that mine was real hard to get off. I thought I was going to break it to take it off.
Jason
Jason 91 is offline   Reply With Quote
