Old 08-17-2022   #1
Bruce Hazell
Default Ignition Key 91 ZR-1
Haven't lost it yet but I'm figuring I should get a replacement ignition key coded for my 91.
I see a couple of sights that advertise them like Ecklers who were a pain to deal with once on something else..anyway...are they available other places and HOW do you know which Vats code you need?
Bruce Hazell is offline   Reply With Quote
Old 08-17-2022   #2
Matt B
Matt B's Avatar
Default Re: Ignition Key 91 ZR-1
I got mine (OEM blanks) from an ebay seller. The VATS codes stand for different resistance of the little metal piece embedded into the key. To be on the safe side just measure the resistance with a common tester
There are translation tables in the internet.
You might also think to override VATS. There is a how to in the solutions section plus there are plug and play solutions available on ebay, too.
Good luck!
ZR-1 #638/1991
Old 08-17-2022   #3
Mystic ZR-1
Mystic ZR-1's Avatar
I hate to say this, but, your Chevy dealer
can probably fix you up. They should be able
to read the pellet and cut the key.
Just be thankful you don't need a current
Mercedes' or BMW key... ☹️
Old 08-17-2022   #4
Young1
Young1's Avatar
My local locksmith has the ignition key blanks and took care of me without delay.
Steve Young
Second Owner
SOLD
SOLD
