05-17-2022 | #1 |
Differential fill plug tool size
Stupid question, but what would be the correct tool to remove the differential fill plug? I tried 8 and 10 mm metric allen wrenches but neither really fits.
Is it an imperial size? Or just super uncommon 9mm? Thanks!
ZR-1 #638/1991 |
05-17-2022 | #2 |
I could not remember what I bought, but I have a long hex just for this purpose. It might be a 9mm as Chris states in this video. Someone mentioned a 3/8 hex is it and I am guessing it might be what I have. 9mm does not sound familiar and why the heck would GM use metric, but we have a mishmash bag of metric and SAE all over the car.
https://youtu.be/HOp67Cr2BNs Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 05-17-2022 at 02:51 AM. |
05-17-2022 | #3 |
Re: Differential fill plug tool size
05-17-2022 | #4 |
Just in case when you are under the Differential, you can add another "Removable Plug"
Just to make sure you have clean Differential Oil Post 147 - ZR1 Added Systems including Differential Case Drain
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-17-2022 at 06:33 PM. |
05-18-2022 | #5 |
It's a 9mm - uncommon size but available (Lisle #33960).
3/8 works out to 9.5mm - doubtful to fit. |
05-18-2022 | #6 |
The rear differential is produced not by GM but by Dana Spicer. I've rebuilt a number of these and every component in it, including the bolts and fill plug, are based on imperial dimensions. Here is a photo of a 3/8" hex socket fitted in the fill plug. IMG_2896.JPG
05-19-2022 | #7 | |
05-21-2022 | #8 |
Thanks for the answers. Tough cookie to get that size over here. Wish I'd known already ahead of the gathering
ZR-1 #638/1991 |
