![]() Join Date: Aug 2017
Check the connecter of the crank position sensor on the right side of the engine or do an ohm test at the connector that goes to the DIS.
I was going to also suggest crank sensor. Without any signal, there?s no spark. Won?t set a code until ECM takes over running motor.
#3 | |
![]() Join Date: Sep 2008
AND the wire itself. Perhaps it was the daily special for the the hungry local rodents. Keep us updated. ![]() Marty |
