![]() Join Date: Mar 2008
I need to get a couple of fuel pumps for my car. What does the collective here think about what kind of pumps I can put in?
Roy
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. ![]() 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 |
I installed ACdelco EP381 pumps last summer. The only pump I could find that wasn't made in China
#3 | |
![]() Join Date: May 2010
The seller of these is a Registry member. https://www.ebay.com/itm/LT5-ZR-1-ZR...-127632-2357-0 Sent from my iPhone using ZR-1 Net Registry
![]() Join Date: Oct 2017
Roy,
The pumps on Ebay are not a bad deal. Plus they are from a member which I think is a plus. When you have the sending unit out, be sure and get one of the billet "Y"s that Carter makes. I have had the original plastic one develop a crack. Use stainless worm clamps and submersible fuel line also. ![]()
Kenny 1990 #442 ![]() |
Roy,
Here's pics of the hose (you will need 5/16 & 3/8) Carter's "Y" and my unit when complete. ![]() z062718-06.jpg z062718-07.jpg z062718-08.jpg
I just checked with Summit and the Walbro pump that Marc suggests is out of stock at this time. It also states that the fuel pressure is only 43 psi, not the 85 psi Marc's article states. Is 43 psi sufficient?
![]() Join Date: Jan 2021
Very good information. Where did you get them? I'm trying to avoid Chinese crap wherever I can. Didn't even have their flu, yet [emoji3]
ZR-1 #638/1991 |
#8 | |
The Rock Auto parts list is: Acdelco EP381 fuel pump Acdelco TS1 fuel pump screen Acdelco TS2 fuel pump screen Spectra LO148 Sending Unit Gasket Last edited by CamP; 03-12-2022 at 09:27 AM. |
![]() Join Date: Sep 2016
Airtex pump E3240
Airtex pump filter FS1 Above Rock Auto O rings at Lowes in plumbing dept.
#10 | |
I looked and they were already sold. The fuel pressure is supposed to around 43 to 45 psi. Roy
