![]() Join Date: Feb 2022
94 ZR-1, with the ignition key on, pressing the washer paddle switch on the multifunction lever will not turn on the wipers or the washer pump. Now, if I turn on the wipers at any speed and then press the washer paddle, the pump turns on and the washers work just fine...looking for any ideas!
![]() Join Date: Aug 2006
In the absence of response, if it were I, I would start with the most obvious and replace the wiper stalk. Perhaps used part from one of corvette salvage outfits.
Thanks, was hoping I didn't need to go down that path!
