Old 01-03-2022   #1
Subfixer
Subfixer's Avatar
Default Secondary valve shaft seal removal?
Looking for advice as to how to remove the secondary valve shaft seals from the heads.
I can't figure out how to get behind them to drive/pry them out.
Thanks.
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige
Subfixer is offline   Reply With Quote
Old 01-04-2022   #2
spork2367
Default Re: Secondary valve shaft seal removal?
I used a a heavy pick tool.
Old 01-05-2022   #3
Subfixer
Subfixer's Avatar
I tried using a scribe to get between the head and the seal. Broke 2 of them. Really trying to not damage the aluminum in the bore.
I need a sharper/harder tool.....
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
Old 01-06-2022   #4
I fashioned a make-shift puller. With an 8-point socket just big enough to span the bearing, a bolt through a fender washer and socket and the bearing with a nut threaded on the end (back of the bearing), and another nut on top of the fender washer. I screwed down the nut against the washer. The bolt pulled the bearings out - easy peasy!
Then I pressed in a Dorman freeze plug with a little JB Weld to seal the hole. If I still have the little rig, I'll snap a pic and post it. - Pretty simple tho - a #6 machine screw about 2-1/2" long, a socket, a fender washer, & a couple of nuts.
Old 01-06-2022   #5
Subfixer
Subfixer's Avatar
Getting the Shaft and bearing out was the easy part.
Getting the seal behind the bearing out is where I'm at. (Unless I misunderstood your explanation)
Old 01-06-2022   #6
Jagdpanzer
Jagdpanzer's Avatar
They will pry out with a flat blade screwdriver. Forget about trying to save the lip seal though.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-07-2022   #7
1991 Corvette ZR-1
Did you remove all the bearings? Curious if you have any pictures of the process. I am looking to do this in a few months.
