Old 11-11-2021   #1
lfalzarano
Default Placement of the air deflector in front of the air filter assembly
I removed the plastic air deflector on my 90 many years ago, that sits in front of the air filter housing and behind the opening in the nose. It?s about 2 feet long and 5-6 inches wide. It has a narrow fold that goes the length and wider fold that goes lengthwise but just about the with of the air filer housing. I have forgotten after all these years.
How is it suppose to be oriented in front of air filter assembly? Any photos or guidance would be appreciated.
Thanks in advance.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 11-19-2021   #2
jss06c6
Default Re: Placement of the air deflector in front of the air filter assembly
I've still got mine on my '91. Should be same on '90..20211119_111422.jpg20211119_111407.jpg
Old 11-20-2021   #3
lfalzarano
Thanks for the photos. There shouldn?t be a difference, but somehow I recall part of it rolled up to the bottom of the air cleaner housing. It your pics it appears to be underneath the bottom of that housing.
When I get it back from the shop, I?ll try it. Clutch master or slave crapped out on me.[emoji35]
