Old 10-12-2021   #6
32valvesftw
Default Re: Oh, what "fun" WTF!?
I had a weird problem with mine where the interior lights would stay on and drain the battery, it turned out that the lock mechanism was sticky and the key was not returning to vertical after I opened the door. That would not explain your other issues though. It sounds like a wire went to ground, perhaps try an ohm meter on the fuse box terminals one by one and see if you get any grounds or opens. Good luck, these kinds of issues take time. Oh I had some electrical issues with a Jeep cherokee recently that turned out to be a battery terminal that could not be tightened, I used a hacksaw to give the terminal a bigger gap and all issues went away. My brothers 2013 Chevy truck had a bunch of weird electrical issues while he was driving it and it turned out that the guy who installed his plow left the battery terminals loose.
