09-27-2021 | #1 |
Random stall when coming to idle
So I have been fighting with a stalling issue. If I am coming to a stop, I usually put it in neutral and coast as I slow down. Every once in a while, the car will stall. Just drop out. It will restart and be fine, usually for the rest of the drive. Just not sure where to look next.
I have: New O2 sensors New injectors New coils New wires Plugs are about a year old New fuel filter Phil's fuel regulator I don't seem to have any vacuum leaks Fuel pressure is solid Outside of the stall when coming to idle the car runs great Thoughts on where to look next?
09-27-2021 | #2 |
Re: Random stall when coming to idle
possibly the idle control motor?
could been old or could just be dirty. John |
09-27-2021 | #3 |
What are your IAC counts at idle?
If you are much higher than 10 it suggests your throttle is closed too much and you are relying on the IAC to keep the car from stalling.(Yes the IAC regulates idle speed but the min. throttle hard stop setting should be high enough to keep the car running just below idle rpm target with 0 counts.) I went through this last month and followed the procedure by XfireZ51 here: http://zr1.net/forum/showthread.php?p=261060#post261060 Have not had a problem since.
Roger 1990 ZR-1 #2699 Black on Black 15,000 miles Full-time secondaries, 4.10 gears, C-beam plates, ported top end |
09-27-2021 | #4 |
IAC was swapped with no change. I did the IAC procedure a couple times. I may need to go through it again but IAC counts are 10 or less fully warm (no AC)
09-28-2021 | #5 |
Jeff, you might check with Marc or stop in to see him. I had this stalling problem shortly after he did his 510 package on the '95 and as I recall he just made a minor adjustment to the throttle cable at the front of the engine. I may be wrong, as it was several eyars ago, but that is what I recall.--Bob
09-28-2021 | #6 |
Thanks Bob,
I have been chatting with him as well.. it happening less now.. time Will tell
09-28-2021 | #7 |
MAP line all clear? This was what stalled mine under the same conditions you?re describing.
09-28-2021 | #8 |
Yes
09-28-2021 | #9 |
My car did than when the camshaft position sensor was bad. Check for codes. I think it is 31?
09-28-2021 | #10 |
Yeah no codes present. But interesting issue with cam sensor
