Old 08-07-2021   #11
Default Re: DIC Bulb Location
Originally Posted by TX '90 ZR1 View Post
Richard,
Was at the car today, so verified the "Service ABS" light operation on it.
The "Service ABS" light illuminates for a short period upon turning the ignition on. Does not stay on very long at all. Maybe 2 seconds then goes out.
Location of the light is immediately to the right of the "Service Engine" light which stays on until car is started.
For reference, my car is a '90 # 0442. I would assume all 90's would function the same, but you know what assuming gets you!!
The ABS is normal as it goes through a start up check upon starting you can even hear the pump behind you momentarily whirring behind the drivers seat
Old 08-07-2021   #12
richarde
Thanks for the replies. No 'Service ABS' light appears in the DIC on initial ignition switch on. The ABS unit behind the driver's seat does whir for a short while on ignition turn on. I know that there is a bulb in the 'Service ABS' location within the DIC as I took a picture of it some while ago when I had the DIC removed. What I do not know is whether that bulb works or has blown! I will check this out. Thanks again.
Richard
1990, numbers 1821 and 2391
1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's
2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch.
richarde is offline   Reply With Quote
Old 08-09-2021   #13
Marc Haibeck
The 'ABS Active' indication was first implemented in '91. It will turn on for a second during the pump self test when the car goes to about 8 mph following key on. In '91 a relay was added to drive the light. The light can be activated on a '90 if you copy the wiring and add the relay as shown in the '91 service manual. I did it once to diagnose a '90 car with big brakes and was locking the wheels too much. The solution to the problem was to change to a brake pad with less friction.
Old 08-09-2021   #14
richarde
Thanks Marc - Really interesting and informative information, especially to those of us with 1990 ZR-1's.
Richard
