Old 06-16-2021   #1
emorse
Default Exhaust System Recommendation
HI, New member with a 1991 ZR-1, 15,000 miles. Considering upgrading exhaust system (maybe just axle back change out). Want a nice Corvette sound but not too loud. Seeking suggestions on recommended providers, ie. Borla, Flowmaster, etc. Thanks.
emorse is offline   Reply With Quote
Old 06-16-2021   #2
Default Re: Exhaust System Recommendation
Lots of posts here and on other Corvette forums; the search function is your friend. Having said that, the only real bugaboo with aftermarket exhaust systems is the presence or absence of resonance or "drone". I recommend leaving the cats in place if you want a slightly quieter sound (and a car that doesn't smell on startup); it sounds like what you are seeking is a cat back system anyway so that should not be an issue. I did most of my exhaust system research a long time ago and I am certain the technology to reduce drone has improve a great deal by now. I had Corsas on both my ZR-1s for many years after trying several others. I really liked the sound and at the time besides the stock exhaust they were the best at eliminating resonance, but I understand several others now also do a good job at that. On my '95 I finally went back to a stock exhaust system and added QTP exhaust cutouts just in front of the mufflers (Marc Haibeck did the work) thereby preserving my spare tire carrier. Allowed me to have a stock-quiet system when I wanted it and anything up to wide open pipes at other times. I normally left the cutouts about one third open for a good sound. Several posts on this here and elsewhere. Also there are probably some good used systems out there that could be shipped since they break down into component pieces. Keep an eye on the parts for sale sections of the forums. The car wil sound much better with a louder exhaust; it is just a matter of how loud you want it and do you want it that way all the time. Good luck with your ZR-1. --Bob
Old 06-16-2021   #3
TX '90 ZR1
TX '90 ZR1's Avatar
I was in the same shoes as you a few years back. I have a '90, no mods. Wanted a bit more of the "Corvette Sound", but nothing obnoxious.
After weighing info gathered from several "ZR-1 guys", keeping in mind performance benefits and sound, I went with the Corsa system.
I set it up to mount just like the stock exhaust, so it is just about a 30 minute job to swap from the Corsa to stock if one wanted.
After using it a while, I would give the Corsa a thumbs up
Cheers
Kenny
1990 #442
Old 06-16-2021   #4
jw63
jw63's Avatar
I put on a Corsa system with factory cats a few months ago, and could not be happier. I do not miss the stock system at all. Sound is perfect in my opinion.
'90 #413 Red/Red Sold
'90 #1583 Red/Red
jw63 is offline   Reply With Quote
Old 06-16-2021   #5
dredgeguy
dredgeguy's Avatar
I have a 92 with Stainless Works headers and Stainless Works high flow cats and Corsa....love the sound. Quiet but when you hit 3500 rpm+ they let people know it is time to play. No drone at any speed.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-17-2021   #6
tccrab
tccrab's Avatar
I have the Flowmaster system on my '90, and can't be happier.
No drone and i can hear myself think inside the car until i hit the go pedal. Then its plenty noisy for my likes.
Someday i will do something about the exhaust tips, although quite functional, they are a little plain to my eye.
'Crabs
Old 06-17-2021   #7
aod
Another vote for Corsa. They sound amazing at all RPMs, zero drone, and stealthy when you are cruising. Eventually I had Marc Haibeck add some high flow cats to them and install my stainless works long tube headers. It all sounds great:
https://youtu.be/uUQZr-xkbXc
aod is offline   Reply With Quote
