Old 12-16-2020   #11
wfot
wfot's Avatar
Default Re: Best Place to Buy Injectors?
I have to ask, what flow rate are the FIC injectors for the Stock lt5? I have heard 20 pounds. and if this is true, what pound injector would be good for a 700 motor? I am overthinking getting Accell 21 pound injectors feeling that they are going to be too small...
wfot is offline   Reply With Quote
Old 12-16-2020   #12
https://www.jerrysgaskets.com/fuel-i...16-90-95-13b2/
Old 12-16-2020   #13
Erik
My set arrived lightning fast from Jerry. Oddly enough, considering the volumes this time of year, it was the fastest delivery I've had yet.
1990 ZR-1 # 996
Old 06-06-2021   #14
Erik
Just to follow up on this, got Jerry's injectors installed, and what a wonderful difference. Smoothed out dramatically right away. Ran through the tank of old gas, gave it a tank of the fresh stuff, and she just began to sing. What a sweetheart of an engine the LT5 is.
1990 ZR-1 # 996
Old 06-06-2021   #15
Matt B
Matt B's Avatar
Glad to hear, congrat! Enjoy the ride, finally it's nearly already spring now
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991
Old 06-12-2021   #16
Give Jerry a call, he's probably just temporary out of stock. His FIC's are matched and require no modifications.
H
I agree - Get the new/stainless FIC "kit" from Jerrys Gaskets. No fiddling necessary.
Before the FIC/Jerrys Gasket marriage, I turned to the Summit Racing #150821s 21# rated) back in 2012 (IIRC) and have had ZERO problems since! The only mod required is grinding off the little plastic indexing (connector) nub for use in the secondary ports only. And, I can tell ya they support 510+ HP w/o any problem in the past 9+ years!
Old 12-19-2023   #17
RC Engineering has an easy BSFC CALCULATOR to help determine injector flow required to support a desired CHP. The stock injector flow is good enough for ~ 540chp w an 80% headroom from static.
I would also recommend not taking flow rates for granted from the supplier and get the Injector Voltage Offset(if available)for better idle performance. You?d be surprised at how much smoother the motor runs when cylinder fuel flow is evenly matched.
https://www.rcfuelinjection.com/Technical
Old 01-18-2024   #18
Starman
Starman's Avatar
I?ve had the RC in my 1991 ZR-1 for 13 years. No issues and very smooth.
Old 01-27-2024   #19
Hib Halverson
I had RC Injectors in my 95 for most of the 20 years I owned it.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-28-2024   #20
Install RCs and then forget about them. Most dependable on the market followed by FICs and or Accels.
