Old 06-07-2021   #1
Vetman
Vetman's Avatar
Default Fuel pump jumper
I purchased the jumper to bypass the main fuel pump if it goes out. I?m driving from Washington state to Carlisle this August and don?t remember how to hook it up if I have a fuel pump failure. Can anyone tell me exactly what to connect to what?
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 06-08-2021   #2
staminqia
staminqia's Avatar
Default Re: Fuel pump jumper
Following
Interested in this thread. WHere can I find/purchase this jumper? I am headed to carlisle too and would love to have that just in case.
staminqia is offline   Reply With Quote
Old 06-08-2021   #3
Fuel Pump Jumper TIPS
Old 06-09-2021   #4
Vettemann98
Vettemann98's Avatar
Originally Posted by staminqia View Post
Following
http://www.zr1.net/forum/showthread.php?t=25149
[SIGPIC][/SIGPIC]
Vettemann98 is offline   Reply With Quote
Old 06-10-2021   #5
Open Fuel Door, Pull the Rubber boot above fuel tank filler with Gentle even pressure towards you, pull the Grey clip holding the fuel pump harness together and plug in the jumper. Its that easy. The Harness may still be clipped to the frame if you have never had fuel pump work before. So you may have to ease it out a little first harness wise. 10 min procedure. GC
Old 06-10-2021   #6
Following
Contact Mr. Jim Voter here on the forum. However be advised he is on a long road trip. His handle is QB93Z. I just sent him a sizeable batch. GC
Old 06-10-2021   #7
staminqia
staminqia's Avatar
You sent Jim a batch of Jumpers? Maybe I can purchase one off of him. I may see him at Carlisle so perfect timing.
Old 06-12-2021   #8
YES
Old 06-12-2021   #9
Once again, the community thanks you, Daryl, for this "must have" item to place in the glove box!! Never had to use either of mine (yet), but little else will do when the primary takes a powder!!!
