Old 05-07-2021   #1
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: Water pump rattle ?
Originally Posted by We Gone View Post
Take the belt off, start it up briefly no noise, check each component.
Thanks Steve,
My initial post may have not been thoroughly clear. Your suggestion is the procedure I used.
Now the inevitable "While I Am In There" question.
I plan on, of course, the water pump and gasket.. Also thinking hoses, clamps, tensioner pulley, air horn gasket and belt.
Anything else I should do? Don't have any oil leaks (already fixed them) so am good there.
Appreciate the feedback.
Kenny
1990 #442
TX '90 ZR1 is online now   Reply With Quote
Old 05-07-2021   #2
Originally Posted by TX '90 ZR1 View Post
Thanks Steve,
Kenny,
Sounds like your on the right track.
Good Luck.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 05-07-2021   #3
TX '90 ZR1
TX '90 ZR1's Avatar
Thanks Guys for the responses.
I am going to peruse it once more this weekend and, if no new findings, will order the parts from Jerry next week.
Kenny
1990 #442
Old 05-19-2021   #4
TX '90 ZR1
TX '90 ZR1's Avatar
Bringing this thread to a conclusion.
Ordered parts (water pump, hoses, clamps, gaskets,) from our favorite parts supplier, Jerry's. Upon removal of the water pump it was obvious it was the culprit causing the rattling sound. The shaft had a bit of play and the noise was being created by the impeller making intermittent contact with the housing. The pump was NOT leaking and showed no signs of previous coolant leakage.
Thanks for everyone's input.
Kenny
1990 #442
