Go Back   ZR-1 Net Registry Forums > C7 ZR1 > C7 ZR1 Technical Postings > Body/Interior
Old 02-25-2021   #1
wkndracr2
Default wheel well cooler openings protection
Before the plastic grid gets broken owners might consider adding stainless steel woven mesh to the grid. I used SS safety wire to draw the screen up to the plastic by wrapping the wire around the oem plastic grate. Works great. I would post a picture but not sure how on this web site.
wkndracr2 is offline   Reply With Quote
Old 02-25-2021   #2
lfalzarano
Default Re: wheel well cooler openings protection
When creating a message, take a photo or attach a photoImage1614286930.920840.jpg like below.
Old 04-16-2021   #3
Hib Halverson
I read on forums that a fair amount of '19 Zroners are worried about the plastic grates and are adding metal screen overlays to them.
Keep in mind that each of those plastic grates is behind two heat exchangers. The front exchanger is for the supercharger charge air cooler and the rear exchanger is an auxiliary coolant radiator.
Whatever extra protection you add, you want to make sure it's coarse enough so that it will not restrict airflow through those heat exchangers.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-15-2021   #4
sjahlgrim
Too late for mine, anyone know if it is easy to order extra from Chevy?
Steve 2019 #2718
sjahlgrim is offline   Reply With Quote
Old 08-23-2021   #5
sjahlgrim
They don't sell the grates septate from the entire wheel well. $155 for a new one. Haven't installed it yet. They old one though is just falling apart and seems brittle given the fact that it is supposed to protect a radiator.
Anyone else having issues with these?
Steve 2019 #2718
Steve 2019 #2718
