#21 | |
![]() Join Date: Mar 2013
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 02-23-2021 at 06:32 PM. |
#22 |
![]() Join Date: Jan 2013
Hello Matt, the sensor underneath the drivers side cylinder head IS the cam sensor (you referred to it as the crank sensor), is this what you're having an issue with? If so, it should be about an inch or so in length and cylindrical with 3 wires attached. It is, or should be, held in place by an aluminum brace and a metric bolt through both the brace and the sensor. I've had mine out a few times as I'm having an issue with the engine running properly and the code pointing to it. I can't imagine the sensor being anything but cylindrical because of the very snug fit into the cylinder head. I believe there are some pics in another thread, I just don't recall which one. I have a couple of pics I think I can add to this thread if you're interested. Stay in touch with this forum and you'll get more help along the way. Good luck.
Rick J ![]() |
#23 |
![]() Join Date: Dec 2007
#24 |
![]() Join Date: Jan 2021
Thank you all for the answers. Of course I'm talking about the CAM sensor. Sorry, language issues...
![]() Considering how much oil is spilled I assume it's cracked as well. If so I'll fix it for now and reach out for replacement.
ZR-1 #638/1991 |
#25 |
Okay, pulled it - and it's cracked... I already dropped Phil a message. Seems that these sensors are a likely painpoint...
ZR-1 #638/1991 |
#26 | |
You should buy one from Phil but also consider attempting a repair.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
#27 |
I'm afraid I am one of many
ZR-1 #638/1991 |
#28 | |
While I am not certain, I am guessing the sensor is potted in some sort of epoxy material which is why these things continue to work even when full of oil. I think most of them are cracked, it is just when that crack makes it into the oring groove, it begins to leak and possibly past the wire entry point.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 03-03-2021 at 05:10 PM. |
#29 |
![]() Join Date: Jan 2004
with the temp swings and oil batch jb weld might not last very long.
You would have to plastic weld that sensor case and it's that crappy hard plastic gm uses that is prone to cracking. put the new one in and be done with it. |
#30 |
Right, I ordered mine from Phil. Will keep the original one in my treasure chest
ZR-1 #638/1991 |
