#1 | |
![]() Join Date: May 2010
Phil is Jagdpanzer on here so you can message him. Sent from my iPhone using ZR-1 Net Registry
![]() Join Date: Jan 2021
Gentlemen, is THAT the crankshaft sensor?!? It's located right below the left cylinder head (driver side). Mine is leaky but it isn't round. I removed a small metal piece (like a small fender, tray, latch, whatever) that was secured with an 8mm nut.
The Sensor itself seems to be not round, there is no twisting possible. I can wiggle it, but it doesn't come out. What am I doing wrong?
ZR-1 #638/1991 |
#3 | |
![]() Join Date: Mar 2013
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 02-23-2021 at 06:32 PM. |
![]() Join Date: Jan 2013
Hello Matt, the sensor underneath the drivers side cylinder head IS the cam sensor (you referred to it as the crank sensor), is this what you're having an issue with? If so, it should be about an inch or so in length and cylindrical with 3 wires attached. It is, or should be, held in place by an aluminum brace and a metric bolt through both the brace and the sensor. I've had mine out a few times as I'm having an issue with the engine running properly and the code pointing to it. I can't imagine the sensor being anything but cylindrical because of the very snug fit into the cylinder head. I believe there are some pics in another thread, I just don't recall which one. I have a couple of pics I think I can add to this thread if you're interested. Stay in touch with this forum and you'll get more help along the way. Good luck.
Rick J ![]() |
