Old 12-09-2020   #21
spork2367
Default Re: I just noticed the inclusion of C6/C7 ZR1s
Originally Posted by Tripler View Post
Not true . The stickies from Dynomite are extremely helpful and yes , it can be a bit of a chore to find your exact issue , but its still beyond helpful and I really appreciate his hard work setting up those stickies .
Sent from my SM-A205W using Tapatalk
Which has nothing to do with the search function. Again, the search here, compared to other forums on the vbulletin platform is very ineffective. I gave an easy example of how anyone can test that out.
Old 12-09-2020   #22
Vette Guy
Vette Guy's Avatar
I spent some time earlier today doing some research. I did try the "valve spring" search on the other forum referenced here and received the same result. Others with the same version of software as us have reported the same issue with this release's search engine - as found on the vendor's own forum. We will continue to look into this.
As Erik stated, the newer generations of software were very problematic. We made a conscious decision not to upgrade to these platforms until a sorted out version is released. The other forum referenced is based upon the last released 3.8.xx version, but with customizations.
Regarding receiving results for your search outside of C4s, this does not occur if you search the current forum. Search the current forum (C4 ZR-1) and you will only receive results posted for C4s.
More importantly to us is preserving Dynomite's Soultions. I spent time on the recommended forum software site learning about it. I'm not done researching, but quickly realize that a migration to another software will completely change the links in the "Solutions", which would be a very time consuming process to repair..... Cliff has invested a ton of work into this over many years, and is a huge factor in any migration we may consider.
Regardless, this is the first we were aware of any issue with the search feature and will work to find a solution.
Regards,
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 12-12-2020   #23
ghlkal
ghlkal's Avatar
FWIW, I welcome the inclusion of C6 and C7 ZR1s.
Originally Posted by Vette Guy View Post
More importantly to us is preserving Dynomite's Soultions. .... Cliff has invested a ton of work into this over many years, and is a huge factor in any migration we may consider.
Agreed. This is an extremely valuable part of the site.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
