Old 12-04-2020   #1
jaykran
Default Speedo not working
Stuck at 0
Anyone have same issue and corrected it?
jaykran is offline   Reply With Quote
Old 12-04-2020   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Speedo not working
You need to first confirm that the speedometer gear is turning and the VSS is sending a signal to the instrument panel.
If that is happening then you likely will be removing your cluster and having the board or circuits repaired.
The manual has a diagnostic procedure for these steps.
Keep us posted.
Good Luck!
Marty
Old 12-04-2020   #3
Mikey
Check if you get any reading on HVAC control display. Hold temp up and down arrows until you get 00 on display. Then tap up arrow until 07. Then press the fan auto button in the middle.
Now drive and see if you get a reading.
Old 12-04-2020   #4
Ccmano
Ccmano's Avatar
Keep us posted.
Good Luck!
Marty
You absolutely need to do the diagnostics in the manual. I had similar one recently, turned out to be a bad VSS, as they usually are. Can be as simple as a bad connection tho.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-06-2020   #5
Marc Haibeck
The most common cause for the speedometer to read zero is an open coil in the sensor. Unplug the sensor and measure the resistance at the pins. It should be about 500 ohms. If you measure infinity, or open circuit, the sensor coil is open. If the sensor tests good, perform the same resistance measurement at the ECM connector. Remove connector A and measure between pin 6, yellow wire and pin 11, purple wire. If the resistance is much higher than 500 ohms there is an open circuit between the ECM and the sensor.
The current Standard Motor Products part number for the '91 - '95 sensor is SC12. The '90 sensor has a different connector and is not available. The workaround for a '90 is to use the '91 - '95 sensor and change the connector.
Old 07-11-2021   #6
Starman
Starman's Avatar
Just replaced the VSS in my 91. As a heads up, Corvette Central was able to provide the AC Delco part, although did list as 94-96 use. Sent them an email advising wider use. Thanks for the great post Marc!
