#11 | |
![]() Join Date: Aug 2006
Although I have also owned 84 Z51, I have no idea what mod is involved to make it bolt up to 91 vette. |
#12 | |
![]() Join Date: Nov 2016
Lt4 Cluster. Brilliant you are.
#13 |
While off topic, I'm also running 96' GS brakes. Looks good but still compatible with stock J55 brakes. I don't race so I don't need big a$$ calipers. Just some bling.
H ![]() ![]() ![]() Last edited by Ccmano; 11-30-2020 at 08:57 PM. |
#14 |
Well, long story short - I was offered a deal on Fikse 18? Profil 10s. When I put these on 13? front and 12? rear calipers didn?t quite fill the void inside. That led to 14? and 13? vented disks and needed calipers to bite these rotors. Like I said, it all worked out.
#15 |
And I thought the stock brakes felt pretty good so far!
#16 | |||
![]() Join Date: Jul 2007
I have a conversion PCB from Batee that allows the 92-96 LCD (however the added functions are not there) Being we have a 1990 the Power key is easy to add, but I don't have the lettering near it. I also replaced the DIC with an LCD. there is no black DIC that has the full power light like our 1990. In the pictures I have the splash ZR-1 in Red for full power and White when not. Considering changing it to be off completely with the key off. I printed a bezel adapter to fit the LCD to the bezel
#17 | |
I wish you were my neighbour. ![]() You've convinced me that it's very doable. And not that hard to do. Nor likely horribly expensive. How come your sports seats look like regular seats? I guess my goal is to not change the car radically, but rather find that best variants of ZR-1 parts to upgrade it.
#18 |
If you do go down this path and want an LCD. I fitted a 5" but had to trim the PCB to make it work, I also did a 4.3 version but like the 5" better. I can supply you with the bezel, but it is suggested you get a DIC a to 'gut' to make it work. There are other parts needed as I need to compile a list for the LCD. I have ideas for the added functions of the LCD but need to by a second LCD so I have one on my work bench for testing
#19 |
![]() Missed this question.. I prefer the style and 'sit' of the standard seats. So I had some covers custom made to fit the sport seat frames and side bolsters. I find the base style with the 'extra' help of the sport bolsters is a good combo. I like the 90 style seats but they get uncomfortable due to the power recline motor location and the way I fit/sit in the seats.. being a bigger guy these are very comfortable now
#20 | |
That part I'll have to kick around. Still sorting out my thoughts around the gauges!
