Old 11-27-2020   #1
ram_g
Default Aaaarghhh...sacrifice to The Valley!
And I was SOOO close...
I've been working on my plenum and injector R&R all week, in between various T'giving commitments.
In the final home stretch, trying to put on that super-fiddly DIS connector in the back, having read all about bent pin horror stories. And learning that key success factors are having thin hands and no beer belly to come in the way as you bend and crane in awkward positions.
And then my 1/4" long socket came loose and fell into the valley! I looked and looked and simply could not see where it went. At that point I was so far into the re-install that I simply gave up and proceeded to finish.
After buttoning everything up, the car started just fine, no untoward noises. It's raining nonstop though, so not a good time to test out the new injectors.
So what does anybody think will happen to the socket? Stay in the valley until the next plenum pull? Drop out somewhere along the way? Will it hurt anything?
ram_g is offline   Reply With Quote
Old 11-27-2020   #2
HAWAIIZR-1's Avatar
Default Re: Aaaarghhh...sacrifice to The Valley!
Sorry to hear this. I know I wouldn?t be able to sleep with a socket in there. I have an inspection camera like this that has saved me more than once finding and fishing dropped tools or fasteners.
https://www.harborfreight.com/27-in-...era-64623.html
The one I have has a magnet, a hook, and another attachment to help fish out stuff. You should give it a shot if you have the patience. Best wishes.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 11-27-2020   #3
Tripler
Tripler's Avatar
Grab a magnet tool with a flexible arm . Maybe you can grab it that way . I knownthe feeling . I found mine had rolled under the car after installing the rear connection . I was lucky
Sent from my SM-A205W using Tapatalk
Tripler is offline   Reply With Quote
Old 11-27-2020   #4
ram_g
Tried blind fishing with a magnet tool, no luck. Have ordered an inspection camera from Amazon, they had several on Black Friday deals. And double checked the garage floor, no luck.
In Marc's plenum DVD he states to get a good grip on the MAP sensor bracket bolts because if one falls, you'll never find it again. But there's a difference between a small black bolt and a 2" long shiny 1/4" socket!
I'm hoping to hear from others that something like this has happened to, where they did not find whatever dropped. And either "yeah, I never found it again" or even "it dropped out and caused all kinds of damage" ... one of those will determine how I sleep tonight!
Old 11-27-2020   #5
HAWAIIZR-1's Avatar
Good deal and understood. Worst case scenario if you can?t locate it with the camera is to just pull the plenum again for more practice. If you ever decide to block off the coolant, the plenum pull is very quick and no mess in the future. I hope you locate it with help of the camera. [emoji1303]🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 11-27-2020   #6
ram_g
Found this thread:
https://www.zr1.net/forum/showthread.php?t=23667
Looks like I'm only the latest (and surely not last) to lose a tool to the ZR-1 valley of doom.
I think I will sleep better tonight.
Old 11-27-2020   #7
ghlkal
ghlkal's Avatar
I think I've lost that socket every time I have the plenum off (4 or 5 times so far and I need to replace the AC compressor, so it will happen again). It is usually on the floor, but I wonder if it did drop in the valley once ...
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 11-28-2020   #8
The only thing I can think of to worry about would be if it made its way under the starter where it might come in contact with the purple (starter) wire if rubber elbow cover was like mine...dry rotted and disintegrating, leaving the connection exposed to stuff like sockets or screws, etc. that might find their way under there.
On the other hand, I tink it would be unlikely for it to get under the coil base plate and then on down to get under the starter. It is more likely (I think) for it to come to rest near the coils?
Were it me? Well, I get paranoid about stuff like that, so I'd pull the plenum and go looking for it. (After my first flurry of plenum pulls [AND plugging the coolant ports] I learned how to save and reuse the gasket and added a pneumatic ratchet to my toolbox - the plenum can be laying on the dirver's side wheel shroud in 10 minutes! I wouldn't give pulling the plenum a second thought...but that's just ME.)
Old 11-28-2020   #9
Found this thread:
Ha! You found my old post. Dropping a 10mm bolt and not knowing where it went (I was taking short cut and injector housing intakes were open) was worse. Drive to discount auto, every magnet tools they had I bought and fished all intakes. Found it in #5 cylinder secondary intake.
Old 11-28-2020   #10
I put just a tiny bit of electrical tape on the 1/4? extension before sliding the socket on the end. That really snugs the socket onto the either the socket driver or 1/4? drive socket wrench.
