![]() Join Date: Nov 2016
When I took my car to the new tech, he removed the ECM for some troubleshooting. He was surprised when he had it out that something inside was rattling. This is what he found:
![]() Join Date: Jul 2007
yes.. car might not run right..
Well I am assuming you are joking.. but, Mine came loose and caused a mness of issues..
Indeed I was. And yes, mine did the same. I had the pleasure for paying for this poor quality repair.
![]() Join Date: Dec 2003
If you want i can solder the chip to your MEM-CAL and will never have that issue again.
Pete
#7 | |
That?s good to know. Let me see how this goes. Erik
![]() Join Date: Aug 2015
Have seen one using the G1 chip adapter come loose. It was the MEMCAL chip assembly detaching from the G1 adapter because the G1 wasn't fully seated. The G1 should "clip" in just like the MEMCAL unit does.
Agree with Pete that soldering is a permanent solution, but the G1 should not cause issues if installed correctly.. Securing the "piggyback" assembly if it came loose is a 5 minute repair... you can add a dab of silicone (for electronics) to help if the G1 to MEMCAL is not tight.37751.jpg Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#10 | |
