Old 11-23-2020   #11
Mystic ZR-1
Mystic ZR-1's Avatar
Default Re: Battery Disconnect Switch
Using a battery tender on a disconnected battery's not a bad idea.
With the disconnected battery you don't have to worry about
the electrical system in the car being "hot".
So, ya gotta reset your radio presets in the Spring?
Old 11-23-2020   #12
BigJohn
BigJohn's Avatar
There?s a Radio???
Old 11-24-2020   #13
Good point!
Old 11-24-2020   #14
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Doug,
For extra measure I drain all of the gas each time I park, to avoid any chance of fire.
I also deflate the tires to prevent an explosion in the event the garage becomes too warm.
Next I plan on removing the glass so no one gets cut should it break.
Am I being overly cautious?
Don't respond til tomorrow.
I shut off my electricity in the house every day to preclude any chance of a bad wire causing a problem.
Marty
Old 11-24-2020   #15
Originally Posted by DRM500RUBYZR-1 View Post
Doug,
Marty
Old 11-24-2020   #16
BigJohn
BigJohn's Avatar
Doug,
Marty
Keep going I am enjoying this story line!
Old 11-24-2020   #17
I drain the blinker light fluid from my car anywhere I go since that stuff is flammable. I don't want my car to spontaneously combust sitting in the garage or wherever I might be
Old 11-24-2020   #18
ram_g
Amateurs!
I take my whole car apart whenever I park in my garage. Can't have any part of the car interact with any other part, too dangerous, and besides it's known in California to cause cancer.
I've done this so often I'm down to 15 minutes for disassembly and assembly.
ram_g is offline   Reply With Quote
Old 11-24-2020   #19
Originally Posted by ram_g View Post
Amateurs!
Let me guess this is your only tool:
Old 11-24-2020   #20
Mystic ZR-1
I'm listening.You guys are right,
SAFETY 1st
So, following Jeff's recommendation,I've
completely disassembled my car for
Winter Storage...
File Type: jpg 9AC03704-9B7A-44EE-A188-23CEE7AD1C97.jpg (157.1 KB, 15 views)
