Old 11-07-2020   #1
rossgn49u
Default Broke down at C.O.T.A.
Well, this sucks. Drove nearly 300 miles to attend the Corvette show at the Circuit of Americas. Just before getting to hotel, last night, 90 ZR-1 started spitting and bucking, then cleared up. Started up this morning, and it barely made it 6 miles to the track. Have CE light and shitish smoke. Car has 70k and have put 1500 miles on it in the last two months with no issues. Any ideas. Any recommendations on an Ausrin shop if I have to have this thing towed?
rossgn49u is offline   Reply With Quote
Old 11-07-2020   #2
billschroeder5842
billschroeder5842's Avatar
Default Re: Broke down at C.O.T.A.
Since you have the CE light the first thing to do is pull the codes. Use the paperclip method, then look up the code on your phone. You are more than half way to fixing your problem.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 11-07-2020   #3
ram_g
Posted reply on CF - probably the nearest ZR-1 specialist is Henderson Performance in New Braunfels, about 50 miles away.
ram_g is offline   Reply With Quote
Old 11-07-2020   #4
Ccmano
Check the MAP sensor vacuum line at the back of the plenum. If it came off the car can exhibit these symptoms. Henderson is the closest. Also check with Steve at Crossed Flags Performance in Magnolia, but that's farther away.
H
Old 11-07-2020   #5
rossgn49u
Just checked with Henderson. They no longer do mechanical repairs.
Old 11-07-2020   #6
ram_g
H
Yep, if Henderson isn't in that business any more, CFP is the next closest, ~140 miles. Unfortunately in the wrong direction from Wichita Falls!
Old 11-07-2020   #7
HAWAIIZR-1's Avatar
You can?t see the vacuum line from the top of the map sensor. You need to reach under to feel if it came off as CCMANO mention.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 11-07-2020   #8
Ccmano
The MAP sensor is under that rectangular aluminum plate. The vacuum line is on the bottom and connects to the back of the plenum.
H
Old 11-08-2020   #9
rossgn49u
Well shoot! Didn't see your post until after the wrecker came. I was just looking for hoses on top. If that is all it is, hopefully Austin Corvette won't hit my wallet too hard. Towing company already raped me.
Old 11-08-2020   #10
rossgn49u
Ccmano.....just noted your production number. Mine is #1466. Red/Black.
