Old 08-08-2020   #151
Tripler
Tripler's Avatar
Default Re: Ruff Idle ,Huge Loss of Power
Just got the new set of ignition coils . 2 of the packages had the orange replacement rubber seal that sits under the coil on the ignition module . Do I need to replace them or am I ok to use the originals because I only have 2 replacements .
Thanks
Sent from my SM-A205W using Tapatalk
Tripler is offline   Reply With Quote
Old 08-08-2020   #152
U should be ok. Use the ones from the good coils just for a bit of margin.
Old 08-08-2020   #153
Tripler
Tripler's Avatar
I called the supplier but won't know until Tuesday if they will send the 2 missing grommets. Would like to have new if possible . I can wait a little longer if I have too and then original ones actually look good and are still soft and not gotten brittle being 25 years old or more .
Thanks
Old 09-10-2020   #154
Tripler
Tripler's Avatar
Up and running again . Idle is smooth . Sounds really good so far . Taking it for a test drive tomorrow .
Thanks again for all the help trouble shooting the trouble [emoji16].
Ride tomorrow will show if it's working correctly.
[emoji846]
Old 09-10-2020   #155
dredgeguy
dredgeguy's Avatar
Well done Mike, you stuck with it and sure that you have solved the problem!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-10-2020   #156
Tripler
Tripler's Avatar
Thanks Charlie . Tomorrow will tell the tale .
Looking forward to the test drive . Weather looks good with cool air temperatures so the Z is gonna enjoy that [emoji1]
Old 09-10-2020   #157
Tripler
Tripler's Avatar
Well scratch the drive tomorrow . My dog just got nailed by a skunk . Jumped in the bath with her to try the tomatoes juice trick . Whole house stinks including me because I had to pick her up and pull her off the skunk .
Not getting in the Z with this smell on me lol . Sitting up all night with her . Locked her in the front foyer with a baby gate . Poor thing . Spray got in her eyes .
Her name is Pogo by the way and she is a Beagle/ Whippet mix .
Tapatalk wont let me upload photos anymore
[emoji19]
Old 09-11-2020   #158
BigJohn
BigJohn's Avatar
[emoji19]
I have been skunked before it takes about two weeks to wear off!
Old 09-11-2020   #159
jss06c6
We've got two Jack Russell's that can't pass on any opportunities to "Hunt", no matter the consequences!
Use Dawn soap (cuts the oil) and baking soda. It's the oil you need to get rid of. Anything you touched in the house is now contaminated! May require professional cleaning or replacement (personal experience!)
Great news on the coils! I had same on my '91! Stumbled under load..
Old 09-11-2020   #160
Mystic ZR-1
Mystic ZR-1's Avatar
You're not coming to coffee tomorrow smelling
like that are you?
