07-01-2020 | #1 |
Oxygen Sensor
Ok, I need to replace my o2 sensors.. does brand matter or are they all made in the same Chinese factory?
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
07-01-2020 | #2 |
Re: Oxygen Sensor
In my opinion brand matters. Bosch 13077 and all my problems went away. RockAuto.com. $30.99
07-01-2020 | #3 |
Re: Oxygen Sensor
I replaced with denso 2343094 . Haven't had a problem at all so far.
07-02-2020 | #4 |
Re: Oxygen Sensor
NGK 21003 purchased of eBay.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
07-02-2020 | #5 |
Re: Oxygen Sensor
I used to use Bosch O2 sensors, but would regularly see the sensor drop signal in my datalogs. I could see strings of 0mv at times. Switched to AC Delcos and have not ever experienced that again. This was not just one sensor, but several, and at different times.
07-02-2020 | #6 |
Re: Oxygen Sensor
I have these also... no problems... I put them on when I added headers.
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
07-03-2020 | #7 |
Re: Oxygen Sensor
Bought a pair of Bosch, arrived today and installed.. need to drive a bit more and get the scanner on it to see how that are working
07-04-2020 | #8 |
Re: Oxygen Sensor
Just to be clear, you will not notice the issue I describe w Bosch O2s as u drive. It is not something that overtly causes a drivability issue. But it is something you can see as you are datalogging. The O2 signal would drop to 0mv on one side or the other. So the ECM would drop out of LEARN and go open loop at times.
I discussed w some tuning gurus, and was recommended to use AC instead. Have not experienced the O2 signal drop since. And there was a difference in the resulting VE map.
