02-09-2020 | #11 | |
Re: Replaced battery, now will not run
Starts up then begins to run rough and dies
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-10-2020 at 12:17 AM. |
02-16-2020 | #12 |
I'm hoping to get sometime this week to work on my car.
Will a bad fuel pressure regulator show with just a fuel pressure gauge on the fuel rail? Can I inspect it with out pulling the plentium? I Sent from my SM-T280 using ZR-1 Net Registry mobile app |
02-17-2020 | #13 | |
Phil's Modified FPR (Before and After Installation.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-17-2020 at 09:32 AM. |
05-24-2020 | #14 |
After some down time due to an attempted theft and having to get the steering column rebuilt, I'm back to trying to fix my car....
I put the column back in, took the battery off the charger, hooked it up and tried to start her... I was pretty shocked when she fired right up and settled into a nice idle. So I let her warm up, and all was good. I went for a drive today, and it was running great, just mobbing on the freeway, doing 70 in 5th. I went to give it some gas and she just fell on her face. I pulled off the freeway and the idle was hung at like 1.5k. It never died, but it was not happy. Felt like it was misfiring, but cleared up once the revs were up. Never got a cel. So. I got home and hooked up my scanner. No codes. The only thing I saw was that the TPS voltage was a little high (.61v) so I set it to .55v. Restarted the car and it ran like ****. Turned it off, turned it back on and it ran fine. It tossed a code 42. I decided to pull the plugs. They looked fine, but I replaced the, anyway. The only thing was that one was really loose, like finger tight at best. After I did that, I started the car and it ran pretty good. I went for a drive and did some data logging. It ran good, but the idle was still hanging. Didn't drive in on the freeway. I've replaced the TPS sensor, crank position sensor, map hose, both fuel pumps. It seems ok when it's cold, but once it's warmed up the issues start. Could a loose spark plug cause this? Would a bad o2 sensor cause this, I'd think it would throw a code? IAC? What should it read at idle and how much should it change when I'm driving? Thanks in advance. Sent from my SM-T280 using ZR-1 Net Registry mobile app |
05-25-2020 | #15 |
Did someone foul your gas?
05-25-2020 | #16 |
I’ve lost several plugs that came loose and popped out. A loose plug gives you a rough idle only in my experience. A blown plug makes a horrible sound!
The high idle might be the IAC. After fixing that, it still ran high. Finally, sent the throttle body to Marc. He found a piece of gunk on the engine side of the throttle plate, causing the high idle. Plus , installed Marc’s chip which also helps. Sent from my iPhone using ZR-1 Net Registry
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR] Last edited by lfalzarano; 05-25-2020 at 07:21 AM. |
05-25-2020 | #17 |
I’m confused, you covered a lot of territory here. You mention several issues but not if they were fixed. Is the high idle the only issue that remains or are there others?
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
05-26-2020 | #18 | |
The idle is still hanging when it's warmed up. It's worse if it's been driving at a constant speed. If im shifting through the gears it's ok. I didn't drive it very far after I replaced the plugs, so I'm not sure if that cured the throttle issue. Sent from my SM-T280 using ZR-1 Net Registry mobile app Last edited by FormulaReed; 05-27-2020 at 12:53 AM. |
06-06-2020 | #19 |
Update: I replaced the IAC today. The old one looked pretty bad and there was a bunch of carbon crud on it and in the housing. I cleaned up the passage way and installed the new one.
I let it warm up and went for a little drive. It seems like the throttle hanging and high idle are fixed. Might just be psychological, but the throttle response felt really good. It still doesn?t come down to idle right away, it takes a few seconds for it to come down. But I?ve heard that?s somewhat normal. It feels like the idle is low, it?s 675 rpm when warm. Is that ok? What are others seeing? Thanks! |
06-09-2020 | #20 |
If you said what year yours is, I missed it. But, mine is a 90 and after highway speed/rpm and comming to a stop, the idle is high initially before dropping gradually to normal over 2-3 seconds.
Also, if for any reason the engine should stall while the car is rolling (happens occasionally on hot humid days with the clutch depressed), the car has to be brought to a complete stop for 2-3 seconds before the idle will return to normal. And, the same thing after shutting the hot motor off to fill the tank; high idle for 2-3 seconds. I've come to accept the behavior as "normal" for a 90, far as I can tell However, my wife's 91 Z does not behave the same way. It never has done the high idle thing - @ least not yet when I've been behind the wheel.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 06-09-2020 at 06:25 AM. |
