#31 |
![]() Join Date: Jul 2007
Second chance do you have a post/ write up of the Spal fan install?
#32 | |
![]() Join Date: Aug 2006
https://www.zr1.net/forum/showthread.php?t=30609 |
#33 |
Did you run the additional 8 gauge wire to the alternator? If so where does the wire terminate? Thanks for the thread! I already got the altenator you recommended
#34 |
If you are asking Secondchance, he said he did in his first post
#35 |
![]() Join Date: Nov 2007
Is there any advantage to adding the 8 gauge and 18 gauge for the fan motor without installing a higher amp unit? I have a brand new stock one form Jerrys already installed.... exercise in futility?
#36 | |
Thicker wire alone, may not have much effect. Last edited by secondchance; 05-15-2020 at 05:18 PM. |
#37 |
Actually the thicker the wire the LESS resistance but the thicker the wire the more current can get pushed through without burning it up.. Heat is generated by the resistance
#38 |
[QUOTE=-=Jeff=-;309294]Actually the thicker the wire the LESS resistance but the thicker the wire the more current can get pushed through without burning it up.. Heat is generated by the resistance[/QUOTE
Without alternator with higher output, what effect would larger ga wire have on fan motor? |
#39 |
More power/current flow to the fans. So the fans would benefit of the larger wiring as there will be less power drop at the fan
#40 |
