Hi,
It has been raining all night. When I entered the car this morning, I noticed the passenger side of the trunk carpet was very wet. Driver side is wet under the carpet but not as much as passenger side. Car is back from a respray. Do you guys have any idea? Car was sitting on a very slight angle, towards passenger side. ![]() ![]() Last edited by MuRCieLaGo; 05-04-2020 at 08:16 PM. |
Check the weatherstrip on the Hatch, especially toward the top.
Betcha it's cracked of separated from the body, maybe even a small piece of masking tape on it. Nice Viper. Neither car should be left out in the rain, word on the street is that they melt. 'Crabs |
![]() Join Date: Jan 2006
Corner right hatch seal. Main body harness connector near right rear of compartment needs cleaning, common, connector likely corroded green .
#4 | ||
![]() Join Date: Feb 2011
Check where the rear glass struts connect to the glass... just a guess that seal might have failed over time.
#6 | |
I called the body shop. He told me he put 3M tape under the seal, instead of OEM glue. He told me the OEM glue is a real pain to work with. I'm pretty sure the problem is right there! |
#7 | |
![]() Join Date: Nov 2007
Anywayz... I used 3M Weather Seal Adhesive (contact cement) on mine. I Pre-installed my seal and put index temporary marks on the seal and the hatch so that after I applied the glue I could be sure that the seal was indexed correctly before pressing it down on the 3M (contact) adhesive. I hasn't leaked in 5 or so years now, and it has sat outside and been driven in several frog stranglers! So far so good. I might add... By the time I got the adhesive spread on the hatch and the seal, it had already dried too much - especially where I first started to apply the (glue). But, according to the directions on another application of contact cement (the head liner, in fact) it said to reapply a third thin layer to one of the contact surfaces and (get this!) proceed to apply the two surfaces together before the fresh adhesive dries to the point of being tacky. Boy, does that work! It gives you some time to adjust the fit after the two surfaces make initial contact. And, once it sets (in 5-10 min or so, depending on how much adhesive was used over all, the surfaces are very secure. (I have also found that third layer technique is especially useful when installing carpet. The carpet can be "squirmed" around to optimize the fit before the (glue) is fully set. Last edited by Paul Workman; 05-11-2020 at 07:45 AM. |
#8 | |
OEM glue is a pain - that's EXACTLY what the body shop said! He was planning on using dum-dum rubber tape. Thanks for your tips!! |
#9 | |
Far as ever having to remove it, 3M Adhesive Remover works as well as any and better than some. I've not had a reason to try to remove that adjesive from my hatch. BUT!! I have used the Remover on painted surfaces when removing emblems without any issues with it removing paint. Good stuff too! |
