Old 04-28-2020   #11
Default Re: Before I buy a new flywheel..
I like the rattle at a stop light. Makes that 5.0 think there’s a junk C4 next to him.
The amount of rattle depends on the tune to a large extent. The more the engine pulses, the less rattle. I don’t have any rattle when driving. If it shows up its when trans is in neutral and clutch is disengaged.
I’m using the BMW trans fluid Steve Schroeder recommends and so far, I really like it.
Old 04-29-2020   #12
A much discussed topic, a decision deserving of careful thought, a conversion involving considerable cost.
Transmission rattle is caused by impulse generated when a cylinder fires. It is absorbed by the DMF so long as the engine is essentially stock and in good tune. This goes for both early & late gear styles in the ZF transmission. The difference in gear styles, straight vs helical, becomes apparent when the conversion to a lightweight, SMF is made. Even the later style, helical gear design develops rattle, but to a lesser degree.
A light weight transmits more impulse to the transmission than a heavy flywheel. A heavier flywheel also makes street driving from a stop easier.
There are alternatives to making the giant leap from the stock DMF @ 37.5lbs to the Fidanza @ 13.5lbs.
Jerrys Gaskets makes an 18lb & a 22lb billet aluminum flywheel with a replaceable, steel clutch surface. Both flywheels have the same dimensions as the stock DMF. This feature maintains the same clutch geometry when using the stock pull-release clutch system.
https://www.jerrysgaskets.com/flywhe...et-90-95-28c1/
https://www.jerrysgaskets.com/flywhe...et-90-95-28c3/
The next obvious question is how much is the noise reduced when compared to the the extreme, lightweight flywheels, like the Fidanza and its counterparts. The answer is subjective and depends on the other variables, tune, cams, transmission gear style, etc.
There is no way to answer, except the lighter the flywheel, the more impulse transmitted to the transmission, i.e. more rattle.
In closing, "rattle" is at its greatest when the transmission is in neutral and the clutch is engaged (pedal released). Some drivers always shift to neutral & release the clutch pedal at stoplights....... other do not. If you do the former and it embarrasses you when others are nearby, then maybe you switch to the later.
There is always going to be some gain & some loss in the conversion. "Choose wisely grasshopper".
Good to know 'bout the flywheels you have. Nooze 2 me!
Old 04-29-2020   #13
Vette73
If you shop the internet you should be able to find a Fidanza light weight flywheel for about ~$375. Keep in mind that there is a high likelihood your transmission will rattle at idle with a single mass light weight flywheel. The degree of rattle varies from barely noticeable to loud and obnoxious. It’s luck of the draw as to how your particular trans will react. If you go this route I highly recommend you add a countershaft shim kit from Carolina clutch to minimize the rattle. The next time my trans is out I will be adding one. The rattle on mine leans towards the obnoxious side. Have fun...
H
https://www.carolinaclutch.com/produ...te-c4-shim-kit
You mean fidanza flywheels rattle ? No.!!! Lol....I feel your pain, and mines cammed...Rattle away....
Old 04-29-2020   #14
Regimof3
I know of the rattle. I've heard it. Not terribly bothered.
It seems Fidanza is the big name in the business so that's where I've been checking. I assume its a zr1 specific part? Like 1 from an lt4 won't fit an lt5?
Regimof3 is offline   Reply With Quote
Old 04-30-2020   #15
Flywheel for LT5 engine is specific, 8 flywheel bolts instead of 6 for LT1/4
Old 04-30-2020   #16
efnfast
On that note, last I knew Jerry was also carrying a flywheel for the LT5
