![]() Join Date: Jan 2005
Does anyone still offer these plates ? Thanks Wayne
C4 Beam Plates
Definitely an improvement if you have ever removed a Transmission and noticed the countersunk area around each of the two forward and two rearward C4 Beam Bolts. This indicates the compression load on the aluminum is too concentrated without the use of a much larger washer (top and bottom Forward and Rearward). The "Washer" (C4 Beam Plates) not only offer a larger area spreading the bolt tensile loads but the C4 Beam Plates are stiffened so they do not flex themselves ![]() ![]() ![]() ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-07-2020 at 10:16 AM. |
![]() Join Date: Aug 2006
I would contact Bill Boudreau.
http://zfdoc.com/c4beamplate.htm |
Thank you they are on their way.
