#1 | |
![]() Join Date: Dec 2003
I have a lightweight, low profile, aluminum floor jack & some small NAPA jack stands that I use for brake & suspension work too. It's all what you get used to I think. Maybe I wasn't specific enough above, but I use the jack & small stands on the 4 post runners. Occasionally, I will use a small bottle jack on the bridge & also keep several blocks (2"x6"x abt 8") in the bridge to put under the engine or suspension to protect from jack marring. I don't find this any more cumbersome to work around than those screw jack stands used with a 2 post. I'm not working against a flat-rate time like a real mechanic, so if it takes a little longer, so what. I know 2 post lifts must be safe or they wouldn't be so popular, but I just feel safer underneath a car on a 4 post. Plus... those runners come in pretty handy to lay tools & stuff on too.
