#21 |
![]() Join Date: May 2005
Steve & Russ -
I was hoping you guys would chime in. I suspect the two of you have probably forgotten more than I ever knew about the ZR-1 plus I gather you are both closer. G - |
#22 | |
![]() Join Date: Apr 2004
Good to hear from ya hope all is well with you and your family.
#23 |
![]() Join Date: Jan 2015
You shouldn't even mention my name in the same sentence as Steve's. He's really a wealth of knowledge. Me? I just try to get by with the minimum. Thank goodness these cars were designed and built so well (once you get past the problems that other people have solved over the years).
#24 |
Russ, you vastly underestimate your skills and overestimate mine LOL, If your able and 93ZR-1 will have us be great to see ya again.
#25 | ||
![]() Keep us posted as seems an interesting challenge with a possible obvious and simple solution ![]() No spark or No fuel ![]() Everything dried out in fuel system over 4 years and something stuck closed or an electrical contact got corroded.. Quote:
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-14-2019 at 05:48 PM. |
#26 |
Looked at the 93 that Joel owns this weekend. Long story short, Its alive removed and cleaned the fuel pumps fired right up. Got a few more issues to sort out next trip. car has been sitting for a while maybe over 5 years.
1. EGR code 32, I'm thinking the valve may be stuck. 2. Both service ASR and ABS lights are on. never dealt with this so any suggestions? Yes I have the 93 FSM but did not have time to pull the codes yet, will do next trip. Everything else looks good the AC even still blows cold!
#27 | |
Pretty sure SGC is no more. 'Crabs |
#28 |
Just a quick update, I have had Joel's 93 for a few weeks now. all the major issues solved (if you call fuel pumps, ABS/ASR lights on major) easy fixes actually and it runs like a top. One very nice completely original 93 40th with under 13k miles. Just needed a little TLC. When Joel picks it up I'm sure it will provide him many miles of smiles.
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 10-15-2019 at 08:29 PM. |
#29 |
I have actually been smiling since the day I met Steve. The car is nice and I appreciate what it is but gaining Steve as a friend is much more important in the big picture. Thank you Steve
#30 |
![]() Join Date: Jun 2004
You need some bling.....
