09-06-2019 | #1 |
A/C compressor is screaming........
It’s got to be a bearing,anybody have any problems like this?
09-06-2019 | #2 |
Re: A/C compressor is screaming........
all the time meaning AC on or off?
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
09-06-2019 | #3 |
09-06-2019 | #4 |
could be the clutch, could be a bearing.. while screaming does it actually work to cool the car?
09-06-2019 | #5 |
If noise only occurs when AC is turned on, probably the clutch worn out & metal to metal.
09-20-2019 | #6 |
Mine squeals when I haven't driven it in a while. Has a new bearing in a new compressor, so only thing it can be is the clutch. It goes away after a minute or two of driving.
Sent from my SM-G950U using ZR-1 Net Registry mobile app |
09-27-2019 | #7 |
don't drive it , mine did that and before I got home I , it cut through the snout of the compressor and couldn't be repaired !
