09-25-2019 | #1 |
Possible Vacuum Leak?
I have a 1995 that runs strong. I noticed the other day when the hood was open that after I turn the car off I heard a hissing sound for a few seconds coming from under the intake (of course....). I don’t recall ever hearing that before. The car doesn’t seem to do it if I start it only for a minute then turn it off. Running the ignition on with engine off vacuum pump test indicates no issues with at least that part of the vacuum system.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
09-25-2019 | #2 |
Re: Possible Vacuum Leak?
09-26-2019 | #3 | |
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 09-26-2019 at 03:52 PM. |
