Old 09-20-2019   #461
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Originally Posted by Mystic ZR-1 View Post
Just pick up a couple buffs for your electric drill and a stick or 2 of compound
at your local hardware store or Home Depot. Not too much $ and easy to do.
(before you put it in the car...)
Recommend a DeWitts 2 row radiator, 32-1139090M, shop around for best price with free shipping...
Thanks or the info....might practice on the old accumulator and see what it looks....copy on the Dewitts….
Originally Posted by DRM500RUBYZR-1 View Post
Tom,
I have the proper and new De Witts Radiator in my stash for your car if you need/want it.
90M new in box.
current price 569.00+ ship
less discount for you taking pictures of Ruby at Carlisle for me
Hows $400.00 and a visit?
Let me know.
Marty
Hello Marty, sounds like a great deal.....I'm assuming 1139090M (Manual) is the 2 row unit, and does that have the two plastic aluminum spacer plates and hardware to fit between the shroud and the fan housing?
Glad to take those pics for you.
Even if I didn't purchase, a visit is still in order....just been crazy busy with the 94 and also trying to wrap up the 74 by the end of October.
Thanks, will chat soon....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-22-2019   #462
Roadster
Roadster's Avatar
Did more fan assembly work today....just thought I would clean everything up and reinstall....but that soon changed....ended up painting everything after the cleaning...
Pic #1....fan assembly apart with replacement fan motor going in...
Pic #2...3 & 4....also pulled other fan assembly apart to paint original motor...
Sent from my SM-G965U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-22-2019   #463
Roadster
Roadster's Avatar
The one fan bracket or holder that the fan sits in accumulated all of this crud in pics #1 & 2 over the years....took a SOS pad and scrubbed it all down.... pic #3 shows how clean and smooth it came out....and that when I decided to paint....as the finish was really dull after cleaning....20190921_162420.jpg20190921_162435.jpg20190921_170354.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-22-2019   #464
Roadster
Roadster's Avatar
Had to think outside of the box with both sides painted and needing to dry without anything touching in pic #1....worked great.....
Pics #2 & 3 are the fan assembly with the new fan motor installed....came out looking decent....other assembly is almost together......just needs more drying time....20190921_205311.jpg20190921_231038.jpg20190921_231104.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-22-2019   #465
Roadster
Roadster's Avatar
Fan assemblies are completed....debating on whether to refinish the fan shroud....if I go with black...then the finished pattern is gone....have to see if there is a paint that will duplicate the original finish...[emoji16][emoji16]20190922_110108.jpg20190922_110134.jpg20190922_115404.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-22-2019   #466
Mystic ZR-1
Mystic ZR-1's Avatar
What do you use the plunger for??? 😋
Old 09-22-2019   #467
BigJohn
BigJohn's Avatar
Sinks , Toilets ,Tubs and Floor Drains!
What do you use them for?
Old 09-22-2019   #468
Mystic ZR-1
https://en.m.wikipedia.org/wiki/Plunger
Big John
We know what you use it for (and other things I won‘t mention...) but I‘m asking Tom and what on the ZR-1 he uses it for... 🤣
Old 09-22-2019   #469
BigJohn
BigJohn's Avatar
Tom did you ever find that missing 13mm socket?
Old 09-23-2019   #470
Roadster
Roadster's Avatar
Doug it's just a photo prop.....
You never know Big John....has many uses.....lol
Big John
Doug....you'll just have to wait and see.....it will be so innovative on the ZR-1 that everyone will be running out to purchase....stay tuned....
No John.....not yet.....might have to turn the car upside down and shake it a few times for it to fall on the floor.....I know it's in there somewhere....
1974 LS4 454 Vert
1974 L-82 355 Vert.
